69 L-68 Intake bolts question - NCRS Discussion Boards
  • Douglas C.
    • August 31, 1990
    • 384
    I just received a nice set of correct intake manifold bolts from Richard Fortier for my 69 L-68. AIM shows a washer for the bolt where the factory lift bracket was, so was that the only bolt that would have a washer?
  • Mark D.
    1984-96 Team Leader
    • June 30, 1988
    • 2168
    Re: 69 L-68 Intake bolts question
    That's the way it was intended but, not the way they all were configured.
    This is my 69 L89 intake which has the washers under where the lifting eye was.
    Kramden
    • Douglas C.
      • August 31, 1990
      • 384
      O/k, now it makes sense. I have 16 bolts from Richard Fortier marked A with 3 lines, but also have 2 TR bolts with washers. I assume I will use 14 of the 16 A bolts and use the 2 TR / washer bolts where the lift bracket would have been. Thanks.
