C1 Hardtop only cover - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    There was a hardtop only rear cover on Ebay . It had the holes for the convertibl top latches on the underside . But not on the top side . he called it a 1960 only . Has anyone heard of this
  • Doug F.
    • November 1, 1983
    • 322
    Re: C1 Hardtop only cover
    my 61 is like that, but my 58 is not
    • Mike M.
      • May 31, 1974
      • 8382
      the non-convert top c-1's i've seen and owned have a cover as you described. mike
      • Steven B.
        • June 30, 1982
        • 3986
        Can I "assume" a soft top only car had holes drilled for the hardtop mounting hardware on the underside but not drilled through on the top side? Does the year make a difference as Doug referred to with his '58 and '61?
        Steve
        • Mike M.
          • May 31, 1974
          • 8382
          fiberglass frame drilled and cut out but the top skin was not drilled or cut out on the hardtop only 56-62's.mike
          • Steven B.
            • June 30, 1982
            • 3986
            Thanks Mike!
            • John F.
              • March 23, 2008
              • 2408
              My 62 (0029) was a soft top only car and there are no holes on either side of the cover for a hardtop, or no holes for the side mounts.
