Re: 427/390 th 400 shifts fine at low speed, under load...will not!!!
Did this just suddenly become a problem? Can you get it past 4000 RPM with moderate throttle?
Not at all common, but a stuck stator in the torque converter will cause RPM to fall flat about 4000 RPM. I have only seen that once in my 40 years of working on cars. Another possibility is restricted exhaust.
