Re: My 365 That Isn't
John,
Higher overlap causes lopey idle and lowered idle vacuum because of the period that both intake and exhaust valves are open simultaneously. Dynamic stroke, and thus DCR is determined by the intake valve (effective) closing event, which as defined by SAE J604d, is the point when it is closing and .004" off its seat. Engines with "big" cams have shorter dynamic stroke, due to later closing intake valves than engines with "small" cams, which is why engines with mild cams use lower SCR than those with higher duration cams. The proper way to design is to design for DCR in the 8.25 - 8.75 range, no matter what kind of cam you're using.
The cam in my 327, as installed 3* advanced rather than the 4* recommended has the intake closing (J604d) at 72* ABDC, which yields an average 8.53:1 DCR. There are some small variations on chamber sizing, and the cylinder with the tightest chamber develops a DCR of 8.65:1. This is very stout and I consider 8.75:1 to be the upper limit for running on pump gas.
John,
