Muncie trans - NCRS Discussion Boards
Muncie trans
  • Morris R.
    • May 7, 2012
    • 213
    Muncie trans
    How many vin #'s should be stamped inside the transmission? Thank you
  • Ralph S.
    • February 1, 1985
    • 935
    Re: Muncie trans
    9 digits on the outside of the main case (example) 16Sxxxxxx for a 1966 Corvette.
    • Tom P.
      • April 1, 1980
      • 1815
      Re: Muncie trans
      On the INSIDE???
      NONE!
        Re: Muncie trans
        Maury -
        There are NONE inside the transmission, but you should find it stamped on the vertical rib on the main case rearward of the side cover with the format 6SXXXXXX; see photo below of the VIN stamp on a '66 Muncie.
