Window handle spacers and oil plug questions - NCRS Discussion Boards
  • Joseph K.
    • August 26, 2008
    • 407
    I have a different color spacer for the right and left window handles. One is gray and the other is white. What is the correct color?
    The second question is in regard to the oil plug on the oil pan. I bought one from Zip because during judging they told me it was wrong. The question I have is is the plug to be painted orange like the engine or left with out paint?
    Joe
    • 15632
    Re: Window handle spacers and oil plug questions
    Joe
    Oil drain plug was installed on the engine when the engine was painted, thus it should be orange. Remember the paint operators had just seconds to do their job and bending over to cover the bottom of the oil pain with a heavy coat of paint was not on their agenda.
    Re: the "spacer" for the window crank. I don't know the answer to your question, but it just might make a difference what year and/or color interior you have. I don't know that it would, just putting a suggestion out there.
    • Joseph K.
      • August 26, 2008
      • 407
      Thanks Terry, The car is July, 1969, for the window handle question. Joe.
      • Kevin G.
        • February 1, 2005
        • 1077
        Joe,
        My thoughts are that the color of the spacer would be an off white/yellowish shade. I believe they where made using a product called Hexamethylenediamine and Adipic acid more commonly known as Nylon6,6. I would also guess these parts where made using and injection molding process. Just a guess?
          • 15632
          Boy am I impressed you can spell that word. You don't think they were stamped out of sheets?
          • Kevin G.
            • February 1, 2005
            • 1077
            Google is my spelling friend!
            I guess they could have been stamped? Isn't there are raised edge around the inner opening/circle? Haven't had one in my hand for a long while now, I'm going by memory?
              • 15632
              I remember a raised edge, but can't remember which inner or outer. It has been a long time in my case as well. We still haven't answered Joe's color question yet, but we have about covered everything else.
                • 15632
                Joe
                Since yours is a late 1969 my early built 1970 may help. Near as I can tell without taking the window cranks off, the handle washers are white -- interior is bright blue. I am not sure if that matters.
                • Paul O.
                  • August 31, 1990
                  • 1716
                  I would agree with the White color any of the early C3 cars that I have helped with and original had White. The Gray from what I remember were later over the counter service replacements.
                  • Ray K.
                    • July 31, 1985
                    • 375
                    My original 1965 has the gray washers behind the window crank handles.
                    Ray
                    • Joseph K.
                      • August 26, 2008
                      • 407
                      Thanks for all of the responses. I based of the responses think I will change the grey one to white.
                      • Mark D.
                        1984-96 Team Leader
                        • June 30, 1988
                        • 2168
                        When I judge interiors, I always deduct for the white ones.
                        Kramden
                        • Kenneth B.
                          • August 31, 1984
                          • 2091
                          All 3 of my 70's are white/yellow white.
                          • Kenneth B.
                            • August 31, 1984
                            • 2091
                            MARK I have been down that road. Try to convince some judges that some plastic parts started out white & turned somewhat white yellow over time. One guy took me to a unrestored 40 year old car & said look it's yellow not white. I tried to explane that plastic wellowes over time. O well.
                            • Mark D.
                              1984-96 Team Leader
                              • June 30, 1988
                              • 2168
                              Just to be clear, I'm occassionally a bit irreverant. I never judge interior because I don't know **** about them.
                              Kramden
