Stamped Or Embossed Logo On 1963 Core Support? - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2039
    A friend asked me this question. He has a core support for one of his 63's that has a logo on it.
    He asked me to check my 63 to see if I had it, and I cannot find anything. The logo on his core support is located on the passenger (RT) side, on the outward facing surface.
    I do not know what that logo is, however.
    Chuck
  • Harry S.
    • July 31, 2002
    • 5346
    Re: Stamped Or Embossed Logo On 1963 Core Support?
    Ah, what core? heater core?
    • Chuck G.
      • May 31, 1982
      • 2039
      OOPS. Sorry Harry.
      The radiator core support.
      Chuck
      • Chuck G.
        • May 31, 1982
        • 2039
        Anybody else?
        Chuck
        • Loren L.
          • April 30, 1976
          • 4104
          Without knowing what it is, could it be a reference to the current reproducer.......
          • Harry S.
            • July 31, 2002
            • 5346
            Chuck, I looked all over the coupe today, no sign of a logo where you said to look.
            • Tom H.
              • December 1, 1993
              • 3440
              Nothing on mine, Chuck.
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
              • Chuck G.
                • May 31, 1982
                • 2039
                I'm going to see him this coming week, and will ask him what logo he sees on his radiator core support.
                I should have gotten that critical piece of information when I talked to him.
                Again, nothing on mine either.
                Chuck
                • Scott S.
                  • September 11, 2009
                  • 1961
                  Chuck
                  Chuck,
                  Could he be referring to the circular 'waffle-iron' stamping? My ('67) radiator support has several of those, including one on the forward-facing upper RH (passenger) side.
                  • Chuck G.
                    • May 31, 1982
                    • 2039
                    Originally posted by Scott Smith (50839)
                    Chuck,
                    Not sure, Scott.
                    I'll do my best to try to catch up with him tomorrow and clarify things.
                    Chuck
                    • Chuck G.
                      • May 31, 1982
                      • 2039
                      Well, I don't have a picture, but I clarified things.
                      The logo is an "L" logo, AND it's on the engine side of the radiator core support, passenger side, UNDER the voltage regulator.
                      Now, I have to admit that I haven't taken my voltage regulator off to check mine yet...................
                      So, sorry for any confusion.
                      Chuck
                      • Scott S.
                        • 1961
                        Chuck
                        Chuck,
                        There is an "L" stamping on the underside of this midyear front end header bar, I'm not sure of the specific model year. If the radiator support has the same simple "L" stamping like the picture below, it may be that the same company that produced the header bars also produced the radiator supports, at least at one point in time.
                        • Chuck G.
                          • May 31, 1982
                          • 2039
                          That "L" logo looks a lot like the one in the picture he showed me. His pic was not that good, as he didn't use the MACRO setting on the camera.
                          Chuck
                          • Jeff Z.
                            • February 1, 1994
                            • 94
                            Chuck,
                            Here are pics of an early 63 radiator support. Support is stamped of both left and right side in same location. Logo looks like MTD. My original April 63 has no such stamping. It does have the cutout and mounting holes for the trans cooler and lines even though it's a manual trans car.
                            Jeff
                            63 Convert 340 hp
                            66 Coupe 300 hp
                            67 Camaro 1500 hp
                            00 SS Camaro 320 hp
                            • Stan E.
                              • April 30, 1991
                              • 383
                              Mine is on the left/engine side and is about 1/2" in diameted.
