the correct generator code for a 59 270 horse - NCRS Discussion Boards
  • Philip M.
    • May 6, 2012
    • 7
    Does anyone know what the correct gnerator code is for a 59 270 horse with an engine build date of Aug 14 1958 the block was cast on june 17 58 and the car was assembled on sept 17 58 its a 270 horse so it needs a deep pulley I expect any help will be greatly appreciated
    Philip McLachlen member 54904
  • Donald H.
    • November 2, 2009
    • 2589
    Re: the correct generator code for a 59 270 horse
    If you have the TIM & JG, the generator specifics are on page 64. The correct generator model is 1102043. If you don't already have a correct one try John Perkle at http://www.johnpirkle.com/. He will also have the correct pulley and will stamp the tag with the appropriate model and dates. Be careful if you are looking. There is a very similar generator that was used on the early passenger cars, 57 for one, that has the drive gear on the back and will work on your 59, but there is some differences in the front and rear end frames.
    Attached is a document that describes these differences.
    C1 Correct Generator.pdf
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
