I had a question regarding the change in location of the fuel filter/strainer that was made between the 1953 /early 1954 which had the fuel bowl at up close to the carbs and the later 1954 being located at the fuel pump itself. I recall an article I read quite some time ago explaining the change but cannot seem to find it. Seems it had something to do with the fuel flow to the carbs but not sure.
Was there a operational or performance advange to having the fuel strainer located at the fuel pump which I would assume was done for a reason?
John
John
