1962 Wonderbar - NCRS Discussion Boards
1962 Wonderbar
  • Jeremy H.
    • January 1, 1999
    • 260
    1962 Wonderbar
    My radio works fine in my 62, but when I push the signal seek it moves once then blows the fuse. Any ideas?
    Jeremy Hedges
    #31711
    Re: 1962 Wonderbar
    Jeremy Hedges
    #31711
    Jeremy -
    Send it to Jerry Rudbeck, www.electrodesign.us
    • John F.
      • March 23, 2008
      • 2415
      Re: 1962 Wonderbar
      Call Jerry at (864)363-0947. He did a couple for me. Top notch!
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Re: 1962 Wonderbar
        It may be internal, but I would check power connections for corrosion, especially the radio ground wire between the pass side case to the engine valve cover. Any looseness could cause extra current draw which could pop the fuse. The seek activates a solenoid which surely draws a large current. Also make sure the fuse is correct. IIRC 7.5 amps?
        If all checks out then Jerry is your man.
