62 radiator - NCRS Discussion Boards
62 radiator
  • Roger B.
    • June 30, 1991
    • 82
    62 radiator
    Can anyone determine the following numbers on a radiator
    top 3150896 bottom outlet 3150897 or 3152087.
    thanks
    • 43279
    Re: 62 radiator
    thanks
    Roger-----
    The 3150896 and 3150897 are casting numbers for the upper and lower outlets of the aluminum radiator used for 1962 Corvettes. They were not available separately from GM.
    • Roger B.
      • June 30, 1991
      • 82
      Re: 62 radiator
      Joe, I'm confused, the 62 judeing manual shows 3150916 as correct for 62.
        • 43279
        Re: 62 radiator
        Roger------
        There's nothing to be confused about. 3150916 is the GM part number for the radiator ASSEMBLY. 3150896 and 3150897 are COMPONENTS of that assembly.
        • Roger B.
          • June 30, 1991
          • 82
          Re: 62 radiator
          Thanks Joe, now I get it.
          Roger Behrens
