Choke Issue - NCRS Discussion Boards
Choke Issue
  • Walter R.
    • January 6, 2009
    • 271
    Choke Issue
    I put recently purchased 3247 carb on engine. Carb taken off had electric choke. I purchased choke kit from Long Island and installed. When engine cold the choke was opened. I read service manual and adjustment is make by bending choke rod. I bent rod as straight as possible and choke not close to closing. After specking with carb supplier I purchased another choke coil and rod from different supplier. Different choke same result. The carb gasket is standard thicknesss so there should be no problem with height. Help
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Choke Issue
    if i remember correctly there are 2 different divorce choke styles one pushes the choke closed and one pull it closed.do you have the correct one ???
    • Walter R.
      • January 6, 2009
      • 271
      Re: Choke Issue
      Yes, the choke coil pulls down on the choke rod which opens the choke plate. When engine is cold the coil spring is in position that has choke open. The end of the coil (Where you attach choke rod) is almost to the bottom of the coil or at about the 4 o'clock position, I hope this makes sense, which puts no upward pressure on choke rod to close choke plate. It would have to be around 1 o'clock position to close plate. There would be a significant amount of coil travel to close the plate.
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Choke Issue
        maybe the coil was put on backwards. can you remove it and reverse it ?? i have had to do this with choke on the carb
        • Walter R.
          • January 6, 2009
          • 271
          Re: Choke Issue
          I thought something like that could be my problem. I ordered another coil spring and rod from another supplier with same results.
          • Paul J.
            • September 9, 2008
            • 2091
            Re: Choke Issue
            A picture would help a lot.
              Re: Choke Issue
              Walter -
              Assuming this is a '66 L-72, do you have the stock casting #3885069 intake manifold?
              • Walter R.
                • January 6, 2009
                • 271
                Re: Choke Issue
                Yes, it is the original intake and I will post a picture tomorrow.
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: Choke Issue
                  Walter, Once in a while Clem hits on something. He is the carb guru in my/our area.
                  A new customer complainted that his 65 FI choke wouldn't work for crap. Problem is that someone put the bimetallic choke spring on backwards. I reversed the spring and it worked like it was supposed to. John
                  • Walter R.
                    • January 6, 2009
                    • 271
                    Re: Choke Issue
                    • Russ S.
                      • April 30, 1982
                      • 2162
                      Re: Choke Issue
                      Walter, Which way does the coil spring go when you bring the engine up to temperature? Finding that out should tell you whether or not the coil is correct.
                      • Timothy B.
                        • April 30, 1983
                        • 5192
                        Re: Choke Issue
                        Walter,
                        Me thinks your choke coil is upside down. With out looking at my 67, the coil when cold is down and after warming the coil expands upward to open the choke.
                        If the lever on the carburetor (where the choke rod attaches) pulls down to open the choke then there is no way the coil can pull down also when cold, something is ass backwards and it seems to me like the coil.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          Re: Choke Issue
                          i always check the direction the choke coil moves by dropping the whole unit in very hot water
                          • Walter R.
                            • January 6, 2009
                            • 271
                            Re: Choke Issue
                            The coil pulls down when heated which is the correct direction to open the choke. It opens the choke fine but does not close the choke at ambient temp, which is pretty warm in Virginia. The pictures show the choke at ambient temperture and you can see the choke plate is opened.
                            • Dave B.
                              • May 31, 2006
                              • 52
                              Re: Choke Issue
                              Walter,
                              This is kind of a stretch, but in the photo it looks like the link from the vacuum unit is resting against the top of the slot in the choke linkage. If it were totally free, I would think it would drop and rest on the bottom of the slot. Is it possible this link is binding the linkage and preventing the choke from opening?
                              Dave Brown
