12 inch wiper blades - question - NCRS Discussion Boards
  • Henry A.
    • May 31, 1990
    • 107
    I have a set of wiper blades that have the same attachment method as my 54. My 54 blades are 11 1/4 inches these are 12 inch. Can anyone tell me if the 12 inch blades are used on Corvettes and if so, what years?
    Thanks for your help.
    Henry Atsma
    54 White/Red
    63 Red/Black SWC
    67 Elkhart Blue/Black BB Roadster
    91 Black/Red ZR1
    96 CE - LT4
    07 Red/Tan
  • John F.
    • March 23, 2008
    • 2415
    Re: 12 inch wiper blades - question
    My 62 has 12" blade inserts. Do you have pictures?
    • Henry A.
      • May 31, 1990
      • 107
      Here are some pic's. Thanks
      Henry Atsma
      54 White/Red
      63 Red/Black SWC
      91 Black/Red ZR1
      96 CE - LT4
      07 Red/Tan
      • John F.
        • March 23, 2008
        • 2415
        Do the ends of the blades have the plastic end caps? They hold the rubber insert into the wiper arm.
        • Henry A.
          • May 31, 1990
          • 107
          No, they do not.
          Henry Atsma
          54 White/Red
          63 Red/Black SWC
          91 Black/Red ZR1
          96 CE - LT4
          07 Red/Tan
          • John S.
            • July 29, 2009
            • 640
            what you have is a RB-12 replacement blade. you are missing a top adapter piece that would allow it to connect on the 56-62 bayonet style corvette wiper arm which use 12" blades. this blade has a different attaching assembly and also does not have the stoppers that were on all the C1 corvettes.
            • John F.
              • March 23, 2008
              • 2415
              Blades with the little tabs on the end.
