Heater box sealer - NCRS Discussion Boards
Heater box sealer
  • Joseph M.
    • June 30, 1999
    • 334
    Heater box sealer
    The factory apparently used a black tar like sealer around the heater box when leaks were detected. Do all cars have this sealer present and would there be a deduction during flight judging if it is not present? What product is being used to replicate this process? Thanks.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Heater box sealer
    Joe,
    Gm only used it on "leakers". No deduct for not being a "leaker".
    • Ara G.
      • January 31, 2008
      • 1108
      Gene
      I got a deduct at Kissimmee Regionals with my 390 car...I argued my point in a nice way that only the leakers got the "goop" treament, all to no avail...They wanted to see the sealant regardless...
      • Gene M.
        • April 1, 1985
        • 4233
        Sounds like some judges need to attend the advanced judging schools. Remember judges are just volunteers and make some calls that are incorrect.
        • Mike E.
          • June 24, 2012
          • 920
          I took a couple of shots of a '65 in Bloomington that had the goop treatment. Not the best images but you get an idea how it looked...This car I think won best of show for a restored car.
          Edit: I'm not sure this is correct...I would like to hear what other folks say.
          • Harry S.
            • July 31, 2002
            • 5344
            When I pulled mu 63 apart, there was no evidence of that black goop anywhere.
            I agree, only the leaker's got it!
            • Michael M.
              • February 1, 1993
              • 606
              From my research the material that was used to fix or detect leaks was sprayed on the heater box where it met the firewall. Note sure if the photos posted above look like the material was applied by spraying.
              • John C.
                • January 1, 2005
                • 616
                I have to agree with Michael, it was sprayed or somehow poured on.
                The attached picture shows the sealer applied on a 68.
                John
                • Mike E.
                  • June 24, 2012
                  • 920
                  I don't disagree with you guys...The photos I posted may not be correct...It looked really strange to me too...I was interested in feedback. I will edit my original post to refect that.
                  Mike
                    The Fourth Edition, Second Printing of the '67 JG (page 119) makes it quite clear that the material is a typical plant "leaker" fix and doesn't necessarily appear on all cars.
                    • Nick C.
                      • August 31, 1998
                      • 542
                      How would an externally applied sealant prevent heater box water leaks? A ridiculous proposition at best, folly at worst.
                      Has anyone in this discussion considered that the externally applied material may have been intended to minimise offensive gaseous engine compartment vapor from entering the interior cabin, much like the sealant applied at other firewall to cabin gaps at the ballast resistor mounting hole, clutch boot, and other firewall to cabin openings?
                      • Mike E.
                        • June 24, 2012
                        • 920
                        Originally posted by Nick Culkowski (30922)
                        How would an externally applied sealant prevent heater core leaks? A ridiculous proposition at best, folly at worst.
                        I believe it wasn't to prevent heater core leaks..It was to prevent water from the engine compartment leaking into the cabin.
                        Mike
                        • Nick C.
                          • August 31, 1998
                          • 542
                          Same theory, to isolate engine compartment from interior cabin.... I have not seen spraying water directly on the firewall as part of a water leak test in the AIM spec.
                          • Mike E.
                            • June 24, 2012
                            • 920
                            I have a searchable PDF version of the '65 AIM...It does mention a sealant on page 227, I'm not sure this is the correct one.
                            I couldn't find anything in the AIM about a leak test either, other than the A/C system (Freon).
                            It's is documented in John's amazing Assembly Process document on page 22.
                            Edit: I searched for "Water" and turned up this in the AIM.
                            Mike
                              • 15634
                              Gene, EVERY 1968-1972 (and I suspect other C3s as well) got the "goop" treatment, and the AIMs call out that sealant on the heater box, and sealant on the grommets where the speedometer, tachometer and oil pressure lines pass through the Instrument Panel. Are you sure that midyears were hit & miss?
