1959 clock - NCRS Discussion Boards
1959 clock
  • Patrick M.
    • July 20, 2012
    • 50
    1959 clock
    How do you remove the clock from the metal panel it is mounted on? Thanks Pat (55168)
  • John F.
    • March 23, 2008
    • 2421
    Re: 1959 clock
    Push in and turn CCW. You can then op the light out and the hot wire. If your hands are small you can wiggle the wire off the back and pull the light from the back before turning.
