1958/1959 vette wheels - NCRS Discussion Boards
  • Gary L.
    • June 19, 2011
    • 62
    Does anyone have the correct gm wheel numbers for an early 59 vette. Have reproduction wheels and cant keep original hubcaps on. Any #'s and pics would be fantastic. Also, would be interesed in buying original set of 4 or 5 wheels
  • David L.
    • July 31, 1980
    • 3310
    Re: 1958/1959 vette wheels
    Gary,
    According to my research GM wheel # 3714744 (15X5K, 9/16" offset, welded) was used on 56 Pass., 56-60 Corvette, and 57-60 Taxi models. GM # 3714744 was discontinued in May 1964 and replaced with GM # 3794464 (15X5K, 9/16" offset, riveted).
    Years ago I had a 15X5K wheel dated "8 54" (riveted type) that was stamped "GM" and had a 2 29/32" dia. hub hole. I assume it was GM # 3707031 as the offset measured about 5/8"". The 3714202 wheel (1955 models) has a 9/16" offset.
    GM # 3707031 was replaced with GM # 3714744 in April 1956.
    GM # 3714202 was replaced with GM # 3714744 in April 1956.
    I don't have any 56-60 Corvette wheels but I recently found a nice set of 5 original 3687980 (15X5K, 5/8" offset, riveted) wheels with original paint and circular pin stripe for 49-53 Chevrolets (and 53 Corvette if the clips are removed).
    Dave
    • Bill M.
      • April 1, 1977
      • 1386
      This is an original wheel for my Dec. '58 assembled '59. It is a "dogbone" welded wheel. No hubcap retention problems (except for midnight auto supply removal service in about 1963):
      • Gary L.
        • June 19, 2011
        • 62
        Thanks. I use to work there! Are your wheelcovers hard to install? These ar nearly impossible and i'm hoping its because they are aftermarket.
        • Gary L.
          • June 19, 2011
          • 62
          Looks like it would be easier to find a set of passenger car wheels for a 56.
          • Tom D.
            • September 30, 1981
            • 2137
            Dave & Gary: I am pretty sure all five of my 1956 Bel Air four door passenger car's wheels are riveted. They are clearly the original wheels.
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Chris S.
              • January 1, 2000
              • 1068
              Gary
              I have one dog bone wheel if your interested.
              • David L.
                • July 31, 1980
                • 3310
                What is a "dog bone" wheel?
                The link below shows 15 photos of one of my 49-53 Passenger wheels (dated "12 51"). Is it a "dog bone" wheel, and if so, why?
                Dave
                Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                • Bill M.
                  • April 1, 1977
                  • 1386
                  Dave
                  I borrowed this from another thread:
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    Gary:
                    Originals are very easy to install.
                    Bill
                    • Tom H.
                      • July 30, 2008
                      • 49
                      Gary,
                      I also had a hard time with aftermarket wheelcovers for my 57. I ended up using stovepipe crimping pliers to shrink them a little and they went on much easier.
                      Tom
                      • Gary L.
                        • June 19, 2011
                        • 62
                        What I have discovered is I have aftermarket wheels and original wheel covers. They will not work together. Found set of 56 chevy passenger car wheels, which are the same gm #, and the wheel covers snap right on very easily. Going to break down tires to verify correct GM # and proceed from there. thanks everyone for your assistance.
                        • Pancho T.
                          • July 31, 1993
                          • 238
                          there are no part numbers cast or stamped on the wheels.The manufacturers log,size and date are stamped inside the rim
                          • Gary L.
                            • June 19, 2011
                            • 62
                            Thanks Pancho.You actually have to remove the tire to inspect the numbers which are located on the center section of the wheel.
