Oil pan - NCRS Discussion Boards
Oil pan
  • Morris R.
    • May 7, 2012
    • 213
    Oil pan
    WOULD A 63-67 OIL PAN FIT A 66 327/350 HP L79 Not sure what year it came off of---it is correct for any high horse mid year 63-66 manuel steering BEST GUESS ANYONE THANK YOU
  • William C.
    • May 31, 1975
    • 6037
    Re: Oil pan
    yes, oil pan rails and front/rear seals are the same in that period
    Bill Clupper #618
    • Morris R.
      • May 7, 2012
      • 213
      Re: Oil pan
      How about a 64 fi oil pan
        • 43290
        Re: Oil pan
        Morris-----
        Any 55-79 small block oil pan will fit any 55-79 small block. The question is whether it is correct and appropriate for a 1963-67 Corvette chassis application. Only 2 oil pans were used on Corvette small blocks over the 63-74 period. The "5 quart" pan is, by far, the most common. It is what a 1966 L-79 was originally equipped with. The "6 quart" pan, originally used for most solid lifter 63-65 applications and some 70-72 solid lifter applications, will fit a 1966 L-79 as long as it does not have power steering or a steering shock absorber.
        The 1975-79 Corvette oil pan, the same as most passenger car oil pans, will fit any 63-74 Corvette as long as the right gaskets are used, but it's not correct or desirable.
        • Morris R.
          • May 7, 2012
          • 213
          Re: Oil pan
          Thanks so much joe that made up my mind!
