Date code - NCRS Discussion Boards
Date code
+ More Options
Posts
  • Morris R.
    • May 7, 2012
    • 213
    Date code
    What are the date codes for a 66 corvette expansion tank did they omit the i in counting the months. Thank you
  • Todd L.
    • August 26, 2008
    • 298
    Re: Date code
    I do not know about omitting the "i" but the code is a YYM The example given in the JM is "66D" = April 66.
    Todd
    • Morris R.
      • May 7, 2012
      • 213
      Re: Date code
      Thank you todd
      • Wayne M.
        • March 1, 1980
        • 6414
        Re: Date code
        I'll go out on a limb here, and say no "I" stamping for the month on expansion tanks, just like another Harrison item (the aluminum radiator). I have an examples of both a 63 M rad (for December 1963), and a 66 M rad, (Dec '65) which means that September was "J".
        • Morris R.
          • May 7, 2012
          • 213
          Re: Date code
          Thank you wayne
          • David L.
            • July 31, 1980
            • 3310
            Re: Date code
            As a "general rule" for all parts the stamped date codes do not use the letter "I" (M = Dec.) while casting date codes do include the letter "I" (L = Dec.).
            I can not think of any date codes that do not follow this "general rule" but there may be an exception or two.
            Dave
            • Todd L.
              • August 26, 2008
              • 298
              Re: Date code
              good info, thank you.
              • Morris R.
                • May 7, 2012
                • 213
                Re: Date code
                Thanks david
