How do You Clean an Aluminum Intake Manifold - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I'm detailing my engine, which I just go back from it being rebuilt and was wondering what is the best method to restore the aluminum intake manifold. I've been able to get the grease and dirt off of it, but there is still some in the porous areas and there are a few scratches on it. Any help would be apprecited.
    Bob Puls, 30633
  • Don H.
    Moderator
    • June 16, 2009
    • 2269
    Re: How do You Clean an Aluminum Intake Manifold
    Bob,
    lots of prior threads on this.
    here is one
    https://www.forums.ncrs.org/showthre...luminum-intake
    I used Aluminum Jelly, like Naval Jelly but for aluminum. Several treatments, and it was clean as a whistle with the original "skin" and sheen intact.
    Of course it will not cure scratches and pitting.
    good luck
    • Bob P.
      • June 30, 1998
      • 143
      Don, Went to a few places this morning and no one has this. In fact the naval jelly they have is not actually called naval jelly anymore. It called rust remover, but it is for steel only not for aluminum.
      Bob Puls, 30633
      • Dan D.
        • November 5, 2008
        • 1323
        I tried buying some last year too, and could not find any, even on the Internet. Used to have it years ago.
        It appears the company has been sold to Loctite. I did not call Loctite, but I would like to have some. -Dan-
        • Don H.
          Moderator
          • June 16, 2009
          • 2269
          Bob, Dan
          the stuff is out there, at Ace or True Value Hardware. My bottle says Duro by Loctite Corp.
          Look here to see some of the places you will find it.
          • Dan D.
            • November 5, 2008
            • 1323
            Hey, that looks good Don. I'm wondering if it has appeared again after been gone for awhile. The E-Bay link shows the Loctite version as a new item, and another version (for half the cost) as made by "Duro". Never heard of that. -Dan-
            • Larry C.
              • April 1, 1980
              • 279
              Saw demonstration on the Speed channel recently on using Sharkhide aluminum cleaner and protectorant. Haven't tried it yet but it looked like it did a great job. Website "www.sharkhide.com" shows their products mostly available at boat dealers but it may be available elsewhere. Spray it on, let it set a few minutes, and wash it off, and you're done.
              Larry
              • George W.
                • July 31, 1998
                • 322
                Robert,
                I clean dirt, grase and fuel stains off my al2 intake with finger nail polish remover. I put my index finger in a rag coated with the nail polish remover and rub on it until it comes off; redo a second time if needed; makes it clean and no damage to the al2 intake. Good luck; it works.
                Dr. George
                • Clark K.
                  • January 12, 2009
                  • 536
                  I don't know what year model engine you have. The aluminum intake manifolds on 60s Sting Rays were painted silver. Are you prepping your manifold prior to painting it? Won't the paint cover up all of the scratches, etc.?
                  -Clark
                    Originally posted by George Williams (30785)
                    Robert,
                    George -
                    Hope you use rubber gloves when you do that - nail polish remover is acetone.
                      Originally posted by Clark Kirby (49862)
                      The sixties engines with aluminum intake manifolds were painted silver.
                      Clark -
                      Not the entire intake manifold - only the side edges, from the operation that sprayed silver on the exposed surface of the cylinder head.
                      • Clark K.
                        • January 12, 2009
                        • 536
                        Clark -
                        John, of course, you are correct. Where the heck did I get the idea that the L76 engine's aluminum intake manifold was painted silver at the factory? It is stuck in my head even though the '65 JG states exactly what you stated.
                        -Clark
                        • Larry M.
                          • January 1, 1992
                          • 2701
                          George -
                          I'm certain that DR George has handled a lot worse than that during his pre-med and medical career.
                          Larry
                            • 15616
                            Larry
                            Dr George is not an MD.
                            • Dan D.
                              • November 5, 2008
                              • 1323
                              All that stuff is absorbed through the skin. Not good.
                              For Aluminum Jelly, I looked in Lowes, HD, and Advance Auto last night. No joy, but the guy in Advance said that he thinks a locally owned hardware store, known as Debbie Supply, has it. I will check this week. Debbie Supply stays in business by carrying everything under the sun. Stuff nobody else carries. -Dan-
