I'm trying to complete my Blue Certification Label for my 72 LT1 Coupe and need the GVWR and GAWR FRT and REAR. Does anybody have that information for a 72 LT1? Also, if anybody knows where I can have these printed I would appreciate it if you could pass on that info. I have labels already.
1972 LT1 Coupe GVWR Needed
Re: 1972 LT1 Coupe GVWR Needed
Robert
Look at reply #22 that should help you out.
https://www.forums.ncrs.org/showthre...fication+Label- Top
MY 72 LT-1 coupe
GVWR is 3910
GAWR Front is 1810
GAWR Rear is 2100
(thats my label in post#22,Thanks Paul)
Mine is a non a/c car with p/s, p/b, p/w, deluxe interior
Don't forget to scroll down the bottom of the page for links to other threads pertaining to the labels.
Regards
RoyLast edited by Roy V.; July 27, 2012, 04:52 PM.1972 LT-1 Elkhart Green Coupe- Top
This label was on a car that was stated just before Christmas and completed after the New Year. Very interesting on all the changes on this label 2 dates different font for the VIN among other items.
DSC01791.jpg- Top
Bob, what's your car's build date? As Reba states, the GVWR data started during the 1972 model year. My early '72 (Aug 23) doesn't have the GVWR info, just VIN and date (mo/yr).
My Fourth Edition TM&JG shows nice pics of each variation. See figures 9.1 and 9.2 on page 23 (Interior). As the manual states, the GVWR depends on engine size, transmission and body style. Manual doesn't say whether/whether not AC is also a factor in GVWR.
If needed, I can/will take a pic of mine for you.
Hope this helps...Don Lowe
NCRS #44382
Carolinas Chapter- Top
GVWR is 3910
GAWR Front is 1810
GAWR Rear is 2100
Hope that helps.- Top
I'm trying to complete my Blue Certification Label for my 72 LT1 Coupe and need the GVWR and GAWR FRT and REAR. Does anybody have that information for a 72 LT1? Also, if anybody knows where I can have these printed I would appreciate it if you could pass on that info. I have labels already.Terry- Top
My '72 has a build date of 4/72. It is an LT1 is a 4 speed non A/C coupe with power brakes and steering. It is VIN 1Z37L2S519247, which is 635 cars earlier then the car Roy posted, so I'm fairly confindent that font should look like the one he posted. I just don't know if there would be a difference in weights because that car is an A/C car?Bob Puls, 30633- Top
My '72 has a build date of 4/72. It is an LT1 is a 4 speed non A/C coupe with power brakes and steering. It is VIN 1Z37L2S519247, which is 635 cars earlier then the car Roy posted, so I'm fairly confindent that font should look like the one he posted. I just don't know if there would be a difference in weights because that car is an A/C car?Terry- Top
Just to clarify, the label in post #5 above is from Bryan Montford's 1972 LT-1 (I believe he has since sold it) it is a C60 a/c coupe and I don't know if he had power steering or power brakes.
GVWR is 4010
GAWR front is 1890
GAWR rear is 2120
Versus
MY 1972 LT-1 coupe, non A/C, with P/S and P/B
GVWR is 3910
GAWR front is 1810
GAWR rear is 21001972 LT-1 Elkhart Green Coupe- Top
Thanks Roy. You essentially have the same car as mine. '72 LT-1 Elkhart Green Coupe with P/S & P/B no A/C. It has a saddle interior. I will use your data to make my certification label and use Bryan's font and layout since it was produced at about the same time my car was.Bob Puls, 30633- Top
