54 in park RPM - NCRS Discussion Boards
54 in park RPM
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    54 in park RPM
    What is the correct RPMs for a 54 ( 6cylinder) in park? Owner's manual states 480 rpms in drive.
  • Jim L.
    • September 30, 1979
    • 1816
    Re: 54 in park RPM
    Not meaning to sound like I'm giving a smart alec answer here: I'd say the correct RPM in neutral and park is whatever will result in the specified RPM in drive. Seriously.
    Jim
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: 54 in park RPM
      Lynn,
      If the engine idles ok at 480 rpm in neutral or park and doesn't stall when put in gear (L, D or R) thats where it should be set. Adjust as needed.
      My 57 PG car idles around 800 -900 in neutral and drops down some when put in gear, as expected.
      I wonder what the specified stall speed is for the convertor?
      • Chris S.
        • January 1, 2000
        • 1068
        Re: 54 in park RPM
        Lynn - mine idles around 650 or so
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Lynn L.
          1953-55 Team Leader
          • February 1, 2000
          • 162
          Re: 54 in park RPM
          Preparing for PV
            • 15706
            Re: 54 in park RPM
            GM typically specifies idle speed in Drive for autos and Neutral for manuals. If you have your idle speed set properly in Drive, that's what you need for the PV. GM did not specify idle speed in Neutral or Park for autos, but it will typically be a few hundred revs higher than in Drive.
            Lacking an OE spec for idle other than Drive, if a PV judge questions idle speed in Park, I would I would protest to the Team Leader.
            A similar situation exists for the initial cold start idle speed. GM specfies the fast idle "hot", and it will typically be a couple of hundred revs lower on a cold start, so PV judges have to allow some latitude here.
            • Lynn L.
              1953-55 Team Leader
              • February 1, 2000
              • 162
              Re: 54 in park RPM
              appreciate help. Lynn
