Is this correct color underside of this 67? - NCRS Discussion Boards
  • Mark U.
    • June 7, 2009
    • 70
    I have to do some minor repairs on my 67s underside and was told that the color would be natural finish. this car was on ebay and said it earned a top flight award-can the underside be painted black?
    • 11643
    Re: Is this correct color underside of this 67?
    The short answer is No, it is not the right color.
    FYI, just because a car earns a Top Flight Award doesn't mean it's perfect. This is a very common misconception.
    The 5% can allow for a lot of "errors."
    Patrick
    PS - here is a better photo, though the green chromate may not be correct for your car:
    • Mark U.
      • June 7, 2009
      • 70
      So when someone has to make a repair use a color added to the fiberglass?
        • 11643
        Or they hit it with black spray paint because they though it looked good.
        • Larry M.
          • January 1, 1992
          • 2689
          Or they paint over the fiberglass to cover major body repairs and replacements.........
          Larry
          • Keith B.
            • March 7, 2008
            • 928
            where I come from that is a rattle can resto to hide bad things
            • Al R.
              • June 30, 1988
              • 687
              Would a 67 have the green chromate finish on the seat & seat belt mounting brackets as shown on Patrick's car underside?
              • Al R.
                • June 30, 1988
                • 687
                • Al R.
                  • June 30, 1988
                  • 687
                  Can't seem to edit my post I FOUND THE ANSWER IN THE ARCHIVES
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    Al,
                    The rear seat mount plates (4pieces, thick) for both AO Smith and St Louis build s/b natural steel, no finish. The four seat belt mounts finish s/b cad or clear zinc again for both AO Smith and St Louis build. The forward long seat mount is shown correct for AO Smith only, St Louis is a black paint finish.
                    Not shown in the photo are the two forward pan shield toe mounts, being green chromate finish on AO Smith and black on St Louis build.
                      • 15599
                      I think that depends if it is a St Louis body or a Dow-Smith body.
                        • 11643
                        That is my understanding as well.
                        I note that the photo I grabbed shows a car with green chromate parts and side exhaust, i.e. what appears to be side exhaust on a AO Smith body. Allegedly that combination did not occur, so either the parts are the wrong color or the side exhaust is added or ?
                        Thus my comment that the parts may not be correct for the OP's car.
                        Patrick
                        • Al R.
                          • June 30, 1988
                          • 687
                          Thanks Gene !! Al
