Dropping a Tank - NCRS Discussion Boards
Dropping a Tank
  • Clark K.
    • January 12, 2009
    • 536
    Dropping a Tank
    How hard is it to drop an empty fuel tank on a '65? I want to remove a former owner's partial rattle can painting of it (on the passenger-side) and install a new fuel gauge sending unit that is rusty and leaking. Also, the car's "squeaking/rattling" over bumps may be caused by a lack of anti-squeak strips on the tank.
    -Clark
  • Keith B.
    • March 7, 2008
    • 928
    Re: Dropping a Tank
    if it is side exhaust its really easy. if not its just one more thing to remove. . if you run the tank about empty your just helping your self
    • Kenneth B.
      • August 31, 1984
      • 2091
      Re: Dropping a Tank
      Not a big deal. Take the tire carrier & exauest down slide3 it out side wayes
        Re: Dropping a Tank
        Clark -
        On a coupe you'll need to remove the filler neck from the tank before rotating the tank down; not necessary on a convertible.
        • Clark K.
          • January 12, 2009
          • 536
          Re: Dropping a Tank
          Thanks, guys. My car has side exhaust, so it sounds like once I drain the tank, disconnect the filler neck & the fuel line, and remove the spare tire carrier, it is straightforward to just drop the tank. I bet I can do this job, myself!
          -Clark
          • Tony S.
            NCRS Vice President, Director Region VII & 10
            • April 30, 1981
            • 993
            Re: Dropping a Tank
            Clark, I would try and source a nice original fuel sending unit. I've heard alot of bad feedback on the Chinese fuel senders out there--leaks etc.
            Tony
            Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
            Original member of the Kansas City Chapter, est'd 07/11/1982.
            Member: 1965 and 1966 National Judging Teams
            Judging Chairman--Kansas City Chapter.
            Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
