1966 425hp cam - NCRS Discussion Boards
1966 425hp cam
  • Jeremy H.
    • January 1, 1999
    • 260
    1966 425hp cam
    Can I get some feedback and the best cam kit for a 66 425hp solid lift cam kit? Maker and part numbers would be helpfull.
    Jeremy Hedges
    #31711
    • 15706
    Re: 1966 425hp cam
    Speed Pro (Federal Mogul) CS165R and AT992 lifters. Look up these numbers on the NAPA Web site. I believe you'll have to have the rear journal groove machined in this cam.
    • Thomas B.
      Infrequent User
      • October 12, 2010
      • 4
      Re: 1966 425hp cam
      I used a melling mselect #22396 .50 duration 242 intake and 242 exhaust. intake lift @ valve .520 exhaust lift @ valve .520 lobe seperation angle is 114 degrees. It seem to work good with compression at 10 to 1 and street use. Dyno still showed horsepower in the advertised range on 425-450.
      Tom
      • Joe R.
        • May 31, 2006
        • 1822
        Re: 1966 425hp cam
        Jeremy,
        Don't use the first design valve spring, they're prone to break.
        Joe
        • Patrick B.
          • August 31, 1985
          • 2012
          Re: 1966 425hp cam
          Tom
          Those specs appear to be identical to the OE 427 425/435 cam. It's probably the FM CS165R in a Melling box.
