C1 Brake Drum to axle fit - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I finally got around to adjusting the brakes on my 1960 restoration project. I finished the chassis restoration about a year ago when I installed new shoes and new brake drums. I had a problem adjusting one of the rear brakes so I decided to pull the drum and check everything. I had a huge problem getting the drum off. These are new shoes and drums, the car has never been on the road. There was no rust and I had the adjustment all the way in, so the shoes were fully contracted. As I wiggles and beat on the drum, it seemed that the drum was caught on the axle not the shoes. I finally got the drum off by using penetrating fluid and heating it around where it fits on the axle.
    I believe the center hole in this aftermarket drum is either slightly to small or even a little off center and gets jammed on the axle when I put it on.
    Will it hurt to grind out the center hole of the drum so that it does not fit quite so tight? I don't know if the drum is centered on the axle by this center hole or by the lug holes or both
    Don
    Don Harris
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C1 Brake Drum to axle fit
    Donald
    It won't hurt a thing. Just grind out as little as possible to fit on axle. Did this on a ralley wheel for my 62 over 18,000 miles ago. No problems with it.
    • Jim L.
      • September 30, 1979
      • 1806
      Don
      Don,
      Do NOT grind the hub hole in a brake drum. Brake drums and rotors are located by a very close fit between the hub hole and the pilot of the hub, or in your case, the axle. If you enlarge the hole, the drum won't be concentric and you'll risk having brakes that shudder and vibrate.
      Jim
      • Donald H.
        • November 2, 2009
        • 2580
        Don,
        Jim
        OK understand. Last question - the fit is so tight that I can not get the drum back over the axle pilot hub. I will either need to use a mallet or lug nuts to snug it on. Is it supposed to be that tight?
        Don Harris
        • Jim L.
          • 1806
          The drum should be an easy slip fit over the hub pilot.
          If you have a set of calipers, verify the hub hole diameter is between 2.813" and 2.818" and that the hub pilot is no larger than 2.813". Of course, it should be slightly smaller than that.
          Jim
          • Donald H.
            • November 2, 2009
            • 2580
            Jim
            My problem may the the axle hub pilot. I measure it with calipers and got 2.15" up to 2.818" at different locations. The drum measures 2.819" in the hub hole. I looked closely at the axle pilot and do not see any obvious damage that would cause the diameter differences. There are no dings or dents from someone hammering on it or anything.
            I may try to clean the hub pilot with some emory cloth lightly
            Don Harris
            • Thomas H.
              • August 31, 2005
              • 1057
              I had the same problem with the new drums I put on my 60. I ended up going over the axle hub area with an emery cloth to remove the years of built up dirt and a bit of rust. Then used it on the drum center hole to remove the paint that was left over from when the drums were painted by the manufacturer. Doing this helped a lot, but they still fit tight.
              Tom
              2007 Z06, Lemans Blue
              • Jerry W.
                • January 27, 2009
                • 588
                After market drum suppliers ( unless authorized by GM ) do not normally have GM drawings, hole sizes or applicalble tolerances. The after market drum is a measured copy of the OE sample drum. If the copied OE drum was at the low side of the OE hole tolerance...chances are that the hole size of the after market drum might be tight because of the after market low side tolerance from the measured nominal of the sample OE drum.
                • Keith R.
                  • August 31, 2001
                  • 660
                  I had the same problem recently - couldn't get the drum off no matter what. Had to borrow a BIG A** two arm brake puller from a Chapter member and that popped it right off. Once removed, I had to take a Dremel tool with sanding drum to sand down the outer diameter of the hub which showed some evidence of hammer damage from someone in the past. If you do this, just Dremel the outside edge of the hub leaving the inside diameter the same. Once I did this, the drum slipped on and off easily.
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
                  2013 427 Convertible
                  Shade tree mechanic and
                  B-52 pilot extraordinaire
