65-66 steering couplings - NCRS Discussion Boards
  • William S.
    • March 1, 2002
    • 55
    Are these statements correct? "The 65-66 standard steering coupling upper flange is bolted to the rag" (per 65 JG). "The 65-66 telescopic steering coupling upper flange is rivited to the rag" (65 JG does not state this, so you assume it's bolted same as the standard).
    I believe this is a 65-66 telescopic steering coupling. It was on my standard steering 65. Now I need to find the correct one for my car and sell this one.
    Thanks for the input.
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 65-66 steering couplings
    Are you sure your car didn't have tele originally? Your statements are correct.
    • William S.
      • March 1, 2002
      • 55
      Is there a way to tell if the car originally had a telescopic column?. It has a standard column now.
      • Jim D.
        • 2884
        I don't know if they're interchangable but the lower support bracket for a standard column has the odometer reset cable knob pointing straight down, for the tele. column it points towards the driver.
        • Russ S.
          • April 30, 1982
          • 2162
          Bill, There really is no way to tell. What Jim says about the bracket is correct however it is easy for some one to have changed although I don't know why they would. Now if your car has both the bracket and the coupler, then I would say there is a good chance it may have had a tele.
