Hi
I have stripped down my distributor from my 71 350 (270).
The bottom gear was on 180 degrees out and there was .025 end play but almost no side movement at all.
When I got it all apart I found a washer on top of the upper bearing between bearing and weight base.
There were no shims at gear drive.
From the diagrams I have reviewed I cant see any that show a washer used above the top bearing.
Could this possibly be someones attempt to remove end play without the correct shims ?
Also would this not move the rotor slightly higher than normal - closer to cap ?
Craig
Craig
