Drain holes for 69 big block hood - NCRS Discussion Boards
  • Danny W.
    • April 1, 2006
    • 40
    Hello friends,
    Can anyone explain how the drian holes are suppose to be under the inserts in the middle of a big block hood ? Are there 2 drain holes on each side or just 1 on the low side and are these a smooth cut or is there breakthrough on the bottom where it is drilled ? If any pictures are available that would be greatly appreciated.
    Thank You
    • 15616
    Re: Drain holes for 69 big block hood
    Originally posted by Danny Watkins (45472)
    Hello friends,
    Thank You
    Sorry I don't have pictures, but one hole per side. The holes are both near the center of the hood, so that would be the low side.
