In another thread I told of my problems with a newly rebuilt (10 miles) L-84 engine. I'm still in the teardown process but am certain I have a blown head gasket. I had water in the #8 cylinder and in the oil pan, and since there is no water passage in the rear of the FI adaptor plate, the water must have entered the cylinder through the head gasket.
The heads were surfaced, as was the block (which they did without touching the stanmp pad). The pistons are new hypereutectic with the same head as originals, new Eagle rods, new valves, springs, seats and retainers. Everything was torqued to specs. I instructed the shop to use an 0.040" composition head gasket and will know later this week if they did. I plan to have the head magnafluxed when I get it off the block.
My question is about the new head gasket when I reassemble. Should I use an .040 composition gasket, or 2 each .020 steel gaskets like what was on the original engine, or something else? Should I coat whichever gasket I use with a sealer (aluminum hi-temp paint; copper gasket sealer, something else)? I don't want to have to go through this again.
Thanks-Doug
Thanks-Doug
