How do you get to the back of the door striker plate on 1958 to replace it, or get stuck screws out to place it? Thanks Jim
Door Latch
Re: Door Latch
I personally would not use heat in that confined area. With the tank out, drill out the screws and remove the plate with the studs in it from behind and do it on the bench. The amount of heat it took me to get them out (on the bench) would have caused damage to the surrounding area of the body.
Dan
- Top
