69 L-68, oil puddle in the intake. - NCRS Discussion Boards
  • Douglas C.
    • August 31, 1990
    • 384
    Hi all. Been trying to find out why my 69 L-68 is running poorly, ignition all good I think, although I wonder if my distributor is worn, I get a slight scraping noise from the distributor cap at times. Erattic idle, off idle stumble. But:
    Thinking the previous owner may have put the center carb manifold gasket upside down exposing the PCV and maybe causing a vaccum leak I pulled the center, and other two carbs.
    Carb gaskets were on correctly, but I look down the intake holes and in the front runners mostly and some in the rear runners I have a small puddle of oil. PCV / hose does not have excessive oil and PCV runner in center of intake is a little moist, but does not look like it is sucking raw oil. When running there is no sign of burning oil. I pulled the center 4 intake bolts but no sign of oil on the threads.
    Now, I just bought the car from a previous owner, and the owner prior to him did the engine rebuild. Stock except for a Comp Cam 280 Magnum. Car has been lying in a garage for a few years with minimal use.
    Since that cam has specs close to a stock L-71 I put in a CV 941 PCV as called for for a L-71. Idle manifold vacuum in the 12" to 13" range. Now, I do recall after speaking to the guy who rebuilt the engine that he had the heads milled somewhat. Block not decked as the matching # pad is untouched.
    So, any thoughts where the oil is coming from? I'm thinking if the heads were milled maybe the intake to head ports are off slightly and allowing oil in the intake. I have not run the car much other than idling, so maybe the high manifold vacuum has worked at pulling in more oil than normal driving.
    Thanks. Doug
  • Douglas C.
    • August 31, 1990
    • 384
    Re: 69 L-68, oil puddle in the intake.
    Since that cam has specs close to a stock L-71 I put in a CV 746 PCV as called for for a L-71. Idle manifold vacuum in the 12" to 13" range. Now, I do recall after speaking to the guy who rebuilt the engine that he had the heads milled somewhat. Block not decked as the matching # pad is untouched.
    Thanks. Doug
    Whoops, corrected to read PCV # CV 746.
    • William C.
      • May 31, 1975
      • 6037
      Define "small Puddle" A drop or two could come down the pcv hose during cooldown.
      Bill Clupper #618
      • Douglas C.
        • August 31, 1990
        • 384
        The front lower runner has a puddle about the size of table spoon full. The other front runner and rear runners less. The valve cover opening for the PCV has a tiny puddle on top of the baffle. These are aftermarket valve covers.
          • 43220
          Thanks. Doug
          Doug-----
          Have you run the engine enough to know what the oil consumption is like (i.e. miles per quart)?
          • Douglas C.
            • August 31, 1990
            • 384
            Doug-----
            No Joe, been having stumble issue, thought maybe previous owner maybe had center carb manifold gasket upside down, exposing PCV slot causing vacuum leak, but after pulling carbs I find what seems like excessive oil in the runners. I have had it idling quite a bit during this stumble issue. Now, I'm using PCV CV746 thinking that is correct, but wonder now if CV 736 is correct. My L-68 is stock except for a Comp Cam Magnum 280. There are no signs of oil smoking at all.
            Doug
            • Grahame M.
              • November 7, 2011
              • 225
              Hi Doug,
              I have the same model and when i removed the carbs to have them refurbished i noticed the same oil puddle. I'm not sure of the cause either but i have the correct PCV valve but replaced alloy rocker covers with repro chrome and correct fittings (not cheap). I'll give it a good run and recheck but could it be the carb wasn't working correctly?? I don't know.
              A friend of mine that has built BB's for a while now suggested that it could be pulling in from PCV. I'd like to know if something is wrong if this is a symptom.
              Unlike yours my engine was running very smoothly prior to carb rebuild and now runs even better. Good steady vacuum suggests engine is reasonably healthy for its age, a bit like me.
              Cheers
              Grahame
              69 427 Tri-Power 4 Speed
              Black on Black
              • Timothy B.
                • April 30, 1983
                • 5186
                Douglas,
                If you are dealing with a stumbling issue at no load conditions like free reving from idle that engine will not drive very well. You may give some thought to removing the two outer carburetors, blocking the intake with a gasket and plate and tuning the center carburetor.
                After you get that sorted out, install the two outside carburetors and tune the secondary's.
                • Douglas C.
                  • August 31, 1990
                  • 384
                  Originally posted by Timothy Barbieri (6542)
                  Douglas,
                  Well, I had the linkage adjusted correctly, throttle plates closed front & rear carbs at idle, if I put my hand over the front & rear carbs no change in idle. Plus, I capped off the rear T fitting on the manifold so no vacuum to headlights, wiper door, etc. Still erratic stumble. So I already now have all carbs pulled off.
                  I wonder if the CV746 PCV I was using is that much different than a correct CV736. But, I think for now I should pull the intake and see if there are signs of vacuum leak, oil on intake gasket bottoms, maybe mating surface to heads not spot on. Previous owner did mill the heads so could be not matching up right to the stock intake.
                  Ignition seems o/k, car runs very cool for a big block, about 190 degrees, does not smoke oil. So, I'm down to intake / carbs / vacuum.
                  Any other thoughts appreciated.
                  Thanks, Doug
                    • 15670
                    Thanks. Doug
                    It may not be oil - but condensed high boiling point components of the gasoline. Is the heat riser passage blocked? You need to go out and get the engine up to operating temperature for at least 30 minutes. The check again for the puddle.
                      • 15599
                      Thanks, Doug
                      Gee, seems to me changing to the correct PCV would be a lot easier than R&R the intake. I would change the PCV first and see what happens -- but that is just me. I am kind of lazy.
                      • Douglas C.
                        • August 31, 1990
                        • 384
                        Thanks Duke, but see above where I mentioned I pulled the carbs already. I will check free movement of heat riser, good thought there.
                        Tks. Doug
                          • 15670
                          I'm not talking about the valve, but you should check it for proper operation. Actually, you should wire it full open.
                          I'm talking about shims installed between the inlet manifold and head that completely block the crossover passage.
                          If the passage is blocked with shims the heat riser valve MUST be wired open. Otherwise, when it is closed at start up there is no place for the RH exhaust to go. This will definitely cause poor operation when the entire RH exhaust system is plugged up.
                          • Douglas C.
                            • August 31, 1990
                            • 384
                            O/k Duke, yep, good points. I'll check this.
                            Now also, my car currently has what looks like cheapo valve covers, probably incorrect oil baffle for the PCV, plus I currently have a CV746 PCV in there.
                            I wonder if the correct valve covers (Cranes?) with the proper baffle and a correct CV736 PCV would make a big difference in oil maybe being drawn into the intake.
                            Tks. Doug
