OBD-I trouble codes - NCRS Discussion Boards
OBD-I trouble codes
  • Martin M.
    • November 1, 1979
    • 124
    OBD-I trouble codes
    HI: where might I get a complete list of OBD-I trouble codes?
    Marty
    Beautiful Pahrump, NV.
    No smog, no rain, no winter, no hurricanes, no tornadoes,
    no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
    vetteheads.com alumni, Boston MA alumni
    1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
    1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
    1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
    1957 Chrysler 300 C 392 Hemi Car
    All for sale - most not cheap!!!
    • 6954
    Re: OBD-I trouble codes
    Martin, whats the code no. maybe I can help? I would also think there maybe something somewhere on the web.
    • Martin M.
      • November 1, 1979
      • 124
      Thanks - Found them at site below - thx to Clem Zahrobsky
      http://www.extreme-check-engine-ligh...%20Decoder.htm
      Marty
      • William C.
        • May 31, 1975
        • 6037
        Really depends on the engine you are running, as the different engine packages had differing calibrations and hardware packages. What Year and engine are you looking for?
        Bill Clupper #618
        • Bill L.
          • April 1, 1985
          • 349
          I use the attached list .... this one is correct for 1994 LT1 Corvettes.... be aware that the C12 code is in fact a delimiter code that just tells you the system is working... any code with a "C" in front i.e. C21, C25 etc is a "current" trouble code... if it has an "H" in front like "H21" or "H25" etc it has been fixed and the code stored in history... there is a simple procedure to clear the codes.. the C12 will remain.... contrary to popular opinion disconnecting the battery will not clear the codes... As you read the codes the system will cycle through each module and display any current or history codes.... or... no codes if there are no current problems and any history has been cleared.
          Regards
          Bill Lucia #8620
          CCM=Module 1
          PCM=Module 4
          ABS/TCS EBTCM is Module 9
          DERM (Airbag) is Module A
          CCM Fault Code List (Module 1.0)
          Code Definition
          12 On-Board Diagnostics Operational; No Codes
          13 DIC Switches Open or Shorted to B+
          14 DIC Switches Shorted to Ground
          16 Ignition 3 Fuse Circuit Open
          21 Horn Relay Coil Shorted to B+ or CCM Internal Open
          22 Rear Defogger Relay Coil Shorted to B+ or CCM Internal Open
          24 Courtesy Lamp Relay Coil Shorted to B+ or CCM Internal Open
          25 Courtesy Lamp Relay Coil Circuit Open or Shorted to Ground
          26 LCD Blanking Control Circuit Shorted to B+ or CCM Internal Open
          27 LCD Blanking Control Circuit Open or Shorted to Ground
          31 LCD Data Circuit Shorted to B+ or CCM Internal Open
          32 LCD Data Circuit Open or Shorted to Ground
          33 Data Clock Circuit Shorted to B+ or CCM Internal Open
          34 Data Clock Circuit Open or Shorted to Ground
          35 Data Strobe Circuit Shorted to B+ or CCM Internal Open
          36 Data Strobe Circuit Open or Shorted to Ground
          37 M Clock Circuit Shorted to B+ or CCM Internal Open
          38 M Clock Circuit Open or Shorted to Ground
          41 Loss of ECM Serial Data Communication
          51 Pass-Key - Invalid Key Detection
          52 Pass-Key - Key Detection Circuit Shorted
          53 Pass-Key - Key Detection Circuit Open or Shorted to B+
          54 Pass-Key - Fuel Enable Failure
          61 Pass-Key - Key # 1 Programming Resistance Out of Range
          62 Pass-Key - Key # 2 Programming Resistance High
          63 Pass-Key - Key # 2 Programming Resistance Low
          71 LCD Dimming Output Circuit Shorted to B+ or CCM Internal Open
          72 LCD Dimming Output Circuit Open or Shorted to Ground
          73 LED Display Dimming Output Circuit Shorted to B+ or CCM Internal Open
          74 LED Display Dimming Output Circuit Open or Shorted to Ground
          LTPWS Fault Code List (x.x)
          Code Definition
          99 Receiver/Control Module Diagnosis
          23 Right Tire Rear Low Tire
          24 Right Tire Rear Sensor Fault
          33 Left Tire Rear Low Tire
          34 Left Tire Rear Sensor Fault
          43 Left Tire Front Low Tire
          44 Left Tire Front Sensor Fault
          53 Right Tire Front Low Tire
          54 Right Tire Front Sensor Fault
          ABS Fault Code List (Module 9.0)
          Code Definition
          21 Right Front Wheel Speed Sensor Fault
          22 Right Front Toothed Wheel Frequency Error
          25 Left Front Wheel Speed Sensor Fault
          26 Left Front Toothed Wheel Frequency Error
          31 Right Rear Wheel Speed Sensor Fault
          32 Right Rear Toothed Wheel Frequency Error
          35 Left Rear Wheel Speed Sensor Fault
          36 Left Rear Toothed Wheel Frequency Error
          41 Right Front Solenoid Valve Fault
          45 Left Front Solenoid Valve Fault
          55 Rear Wheels Solenoid Valve Fault
          61 Pump Motor or Motor Relay Fault
          63 Solenoid Valve Relay Fault
          71 Electronic Brake Control Module Fault
          72 Serial Data Line Fault
          75 Lateral Accelerometer Fault (Short ot Open)
          76 Lateral Accelerometer Fault (Signal out of Range)
          SIR (Airbag) Fault Code List (AKA DERM) (Module A)
          Code Definition
          21 Steering Column Circuit Resistance too High
          22 Steering Column Circuit Resistance too Low
          23 Steering Column Circuit Voltage too High
          23 Steering Column Circuit Voltage too Low
          25 Short to Battery in Steering Column Circuit
          26 Open in Steering Column Circuit
          31 Open 36 VLT to Deployment Loop
          32 Grounded 36 VLT to Deployment Loop
          33 History Code, Diode B Shorted in Wiring Harness to Arming Sensor
          34 Open in Ignition 1 Feed to Deployment Loop
          35 Discriminating Sensor Open
          41 and / or 42 Deployment Loop Energy Reserve Voltage Fault
          51 Accident Detected
          52 EEPROM Accident Data Area Full
          61 Force Low or "INFL REST" Warning Lamp Circuit Failure
          71 Internal DERM Fault
          • Bill L.
            • April 1, 1985
            • 349
            NB: C12 is not an error code but indicates the On board diagnostics are operational.
            • Bill H.
              • August 8, 2011
              • 439
              What Bill shows is correct for a 94 (I think for 95 also).
              If you have a 92-93 both the jump positions on the ADL connector (paperclip) and the codes are different.
              I have the complete procedure on an Adobe PDF file and can email it to you.
              • Bill L.
                • April 1, 1985
                • 349
                Hi Guys:
                My understanding is that the 94 and the 95(maybe?) use an OBDII connector but the system is based on OBDI.... I know my 94 has an OBDII connector so you jump pin 4 to 12 to get the codes... OBDI codes get displayed.......not sure what pins to jump if have an OBDI style connector on the 92-93 cars....
                Regards
                Bill
                • Bill H.
                  • August 8, 2011
                  • 439
                  Originally posted by Bill Lucia (8620)
                  Hi Guys:
                  Regards
                  Bill
                  Yep, correct Bill
                  The pins on the ADL for 92-93 are lettered. You jump A & G which, looking at the front of the connector, A is on the bottom row to the far left and G is on the top row to the far right.
                  And the codes are different.
