Hi Guys,
I recently drove my L76 (30-30 cam) 1965 Coupe to the NCRS National Convention in San Diego. While there I ran into Duke Williams who graciously helped me to better understand the specifics of the 30-30 cam and to improve the performance of my engine and eliminate/reduce detonation. Duke suggested that I start a new post on the forum so that anyone else running a 30-30 cam might benefit from our experimentation and “tweaking” on the motor and setup. So here it is… I hope it may prove to be informational or helpful to others who are running the 30-30 cam in their car. First – a BIG THANK YOU to Duke Williams for all of his insight and assistance. Thank you Duke! Now - the background…
My Car Setup:
The NCRS Run:
Summary:
I am happy with the engine’s reduced detonation – and am grateful to Duke for his time and assistance. I believe that the reduced detonation to be the result of the tighter .025” valve lash. I think that I will continue to run 2.5 gallons of 110 octane race fuel in each tank. I may experiment with reducing the primary jets back down to 69s or 67s – and put a sniffer on the car to truly assess the carb mixture. I am still somewhat concerned about the increased engine temp and tendency to stall. I am looking into potential remedies like blocking off the cross over ports or even changing the fuel pump to try to remedy the stall situation. I may also play with the valve lash (changing it between .023 - .027) just to see how this affects overall engine performance and temperatures… Please let me know if you have any advice, thoughts, or observations in your own engines. I hope that my story helps others who are running 30-30 cams in their small blocks.
Thanks again Duke!
Cheers,
Dennis Kurimai
Member 33979
My Car Setup:
- 1965 Coupe with L76 Engine Option, close ratio 4-speed, and 3.70 Rear-end.
- “Blueprinted” 30-30 Cam installed (this cam was blueprinted by CRANE Cams’ lead cam grinder – CRANE was the OEM manufacturer for GM’s 30-30 cams from mid to late 60s).
- Actual compression = 11:1. This is the actual compression on the engine
- Engine bored .030” over; engine was machined and zero decked. All rotating assembly balanced. Each valve spring was tested/shimmed appropriately to ensure proper lift.
- Rocker Arms – running theoretical 1.5:1 ratio rocker arms (but with roller tips).
- Stock Holley 4-barrel carburetor (List 2818). (I have experimented with Jets – please read below, but currently run 77s in the secondaries and 70s in the primaries)
- Heads – I am running the later hi performance small block heads with the larger valves. For clarity, these are not the stock “fuelie” double hump heads. I am running the heads that GM installed on later Comaros and Corvettes with high performance cams. They have bolt holes on the front of the valve head and larger intake + exhaust valves. I have done some mild porting/bowl/blend work to match the heads to the block.
- Stock distributor with Mallory ignition (replaced the points with Mallory photo-optic unit). I am running a NAPA replacement vacuum advance can (model B28). The distributor and vacuum can was “dialed-in” on a distributor machine so that it is exactly as per GM spec for the car
- Compression is approx. 155 - 160 ft/lbs. on each cylinder.
- Valve lash set at .025” (tight) when engine is cold.
- I run 10w-40 Royal Purple synthetic motor oil.
- I typically run approx. 2.5 gallons of Sunoco Purple (110 octane leaded race fuel) per tank. The remaining 17.5 gallons in each tank is a “top-tier” 91 POM octane fuel from Shell or Chevron.
The NCRS Run:
- San Diego to Santa Clarita (the base of the Grape Vine on I-5)
- Santa Clarita to Los Banos (the heart of the CA Central Valley near Fresno)
c. Los Banos to SF Bay Area
Summary:
Thanks again Duke!
Cheers,
Dennis Kurimai
Member 33979
