wiring horn relay 1970 - NCRS Discussion Boards
  • Richard H.
    Infrequent User
    • July 31, 1991
    • 22
    I am working on a 1970 coupe 350/350 4 speed with air. I have several wires that go to the horn realy which were removed. Does anyone have a picture of how these wires are connected? Several elctrical components on the car do not work. Making sure the wires are connected properly on the relay, from what I have read is the first step to solving my problem?
    Rich Harris
    • 15616
    Re: wiring horn relay 1970
    Rich Harris
    Rich,
    There should be a page in the AIM that shows the standard (less C60) wire hook up to the horn relay, and a page in the C60 section for the single red AC power wire. Later today I will be in the garage and I can get you the page numbers for those illustrations, if you can't find them on your own.
    • Kenneth B.
      • August 31, 1984
      • 2091
      You need to get the 70 Assembly manual from NCRS
