85 hatch manual release - NCRS Discussion Boards
  • Quentin W.
    • February 1, 1979
    • 7
    Have the top stored in the lugs in the hatch area. Tried all three release buttons none work. Can I get to the manual release cable through the gas cap area. Any precautions?
  • John D.
    • August 31, 2001
    • 280
    Re: 85 hatch manual release
    I don't believe you can. You might be able to reach it with long-nose needle nose pliers a flashlight and reaching it under the stored top. It should be possible, but I have not tried it.
    Good luck!
    • Peter M.
      • April 8, 2007
      • 570
      Check for a blown fuse, If that's not it, then you may have a bad courtest light delay module which also controls the hatch release and the convertible top hatch release on later models.
      • Quentin W.
        • February 1, 1979
        • 7
        Thanks Am 86. Did not think I could bend that much. Cable was broken Found the right end and POP. Am looking for the way to get the top storage release handle off so I can get to the latch. I assume the solenoid is in the same area. I am the original owner so I want to keep it original. Quent
        • Patrick N.
          • March 10, 2008
          • 954
          The latch should pull off from the top. I had a similar issue with My 88 - solenoid was bad, replaced the solenoid and it is working fine ever since. solenoid was easy to remove once you get the plastic cover off.
          Best
          pat
            • 6950
            Quent, can you just un-screw the front mount/mounts from the floor? might be a opition. Ed
