Re: No steps forward and 3 back.
Hi Doug,
Antifreeze usually burns as thick white smoke, almost like steam only thicker. Did you find water in the oil? You might find oil in the coolant as well or instead. If the oil is clean, refill your tank and run it a bit to see if there is oil floating in the tank. If you find water in the oil, obviously, don't run it and don't leave that oil in the pan. Shoot some fogging oil into the cylinder that has the water, if you find it, until you repair whatever it is that caused it. Maybe someone knows a better product for that application. Good luck! It sounds like you're real close to being finished. Very frustrating.
Mike
Hi Doug,
Mike
