1967 header bar in the front clip - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    for the header bar in the front end for the holes for the emblem. should the hole have a lip towards the top (like it was punched out) or should it be flat. did it change though out the run of the mid years?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1967 header bar in the front clip
    I deleted my original post as it appears it was wrong. I looked at a 67 that had the flat hole however it has had some front end damage. I have access to another 67 that I will check.
    • Keith B.
      • March 7, 2008
      • 928
      Russ I looked at one original no hit car and dads no hit 67 and both are flat. dads other 67 is a St. Louis body, I forgot to see where the other car body was from.
        Keith -
        Those front emblem access holes changed from '66 to '67; the holes had a rolled lip in '66, but they changed in '67 to ordinary pierced holes with no lip or flange.
        • Keith B.
          • March 7, 2008
          • 928
          thanks John. did A.O. Smith use the same supplier as St. Louis
            Keith -
            Yes, they did - there was only one supplier that shipped to both plants; as I recall, it was Chevrolet-Indianapolis Stamping. Indy also made the radiator supports and most of the birdcage stampings.
            • Nick C.
              • August 31, 1998
              • 542
              Perhaps Chris E will post a photo of his early restamp header bar.
              He has a little of both...
              • Keith B.
                • March 7, 2008
                • 928
                Oaky thanks that helps my case on what it should be
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  Up to the first 1000+ had the old 66 style rolled lip, with the 67 modification which was an overlapping hole with the sharp edges.
