65 heater air flow question. When the defroster control knob is fully deployed is any air expected to come out the floor vent. It is ever so slightly. I am getting the car ready for PV and need it right.
65 heater air flow
Re: 65 heater air flow
Bob -
You should check with your National Team Leader (Mike Murray) for the definitive answer, but the two attachments below show how the defroster door seals to the inside of the heater case. The foam seal is only at the end of the door, and the design allows some airflow past the sides of the door when it's down, in the full defrost position. I don't recall whose photos these are - might be Dave Zuberer.
HeaterBoxDoor.pdfHeaterBoxDoorPositions.pdf- Top
