Spark plugs - NCRS Discussion Boards
Spark plugs
+ More Options
Posts
  • Ed K.
    • March 1, 1980
    • 110
    Spark plugs
    AC Delco plugs for a 64 327 come without the washer installed on the plug. The washer has a large diameter face with a small diameter on the opposite side. Does it matter which face is against the plug?
  • John D.
    • December 1, 1979
    • 5507
    Re: Spark plugs
    Ed, I often thought the same question for an eon . I don't think it makes a difference at all. I never saw anything in writing about it and I also have never seen a post here asking the same question. Now to wait for a better answer. John
    • Ed K.
      • March 1, 1980
      • 110
      Re: Spark plugs
      I just sent an email to acdelco.com regarding my plug question. I was hoping to put the plugs in this AM but instead will wait for their response (NCRS responses are much quicker). I'll post their answer.
        • 15706
        Re: Spark plugs
        It's not a washer. It's a gasket - made out of copper - and designed to crush as the plug is tightened to the proper torque. It's made from two pieces that are crimped together leaving a crush space. It shouldn't matter which way they are installed, but I always installed them with the crimp facing the plug.
        I haven't bought AC plugs in decades, but I recall that over-the-counter plugs always had a gasket in the box, and, of course, there were gaskets on the Flint-installed plugs.
        Back when I had "plug fouling" problems and was always removing plugs for cleaning (which later turned out to be a sloppily assembled distributor all along) I bought a box of 100 of those gaskets.
        Some racers installed the plugs without gaskets, which reduced combustion chamber volume slightly for more compression.
        Don't expect much from "Delco". It's just a marketing organization, and I doubt if they have any job classifications that contain the word "engineer".
        • Ed K.
          • March 1, 1980
          • 110
          Re: Spark plugs
          Thanks Duke. Yep, Delco suggested I contact an authorized AC Delco parts distributor, which turned out to be a local repair shop.
          Their response was to install with the larger face towards the plug unless the mating head surface was rusted or damaged, thereby creating a bad sealing surface.
          And............I should have referred to them as gaskets - oops!
          • Bill M.
            • April 1, 1977
            • 1386
            Re: Spark plugs
            The gas station I worked in had a plug cleaner and I cleaned a lot of plugs until I learned to run a hotter heat range. I always installed new gaskets. I still have a few gaskets left. I don't think I've seen these since the 60s! I believe that my first box had copper gaskets.
