Re: Factory AC. Holder for evaporator inside evaporator casing
Claus,
If you are looking for the stud plates, the small ones (like those used for the under-dash heater distributor) are reproduced, but I don't think the bigger "T-studs" for the C60 Evaporator housing are reproduced. I had to repair one of mine, and it doesn't look quite right, so if you find a good replacement, please let me know.
As for the long stud-plate in your picture, you might be better off fabricating that part yourself, if you can get accurate dimensions. Mine is still on the car, but the car isn't with me at the moment. I can get the measurements for you eventually, just not sure how soon. One of the members here recently had a complete C60 system available on the auction site, and part of his listing said "4) Includes the rare inside the "A" pillar recirculating air ductwork, the rh kick vent and mounting bracket and the upper stud bracket required to mount under the rh wiper grill so studs are there for mounting outer box." (emphasis mine)
You might be able to get measurements for the longer stud-plate from him, the eBay listing is ended now but can still be found if you search for listing number 140779263071.
Along with the dimensions, a trace-outline would be helpful, scanned at full size to pdf, which could then be emailed to you for a pattern.
Claus,
I see. Well no need for me to worry about that part since it sits on the evaporator.
