Gear ratio ?????????? - NCRS Discussion Boards
  • Morris R.
    • May 7, 2012
    • 213
    Can anyone figure out what ratio i have in my 66 corvette 327/350hp l79? Going 70 miles per hr and reading 3000 rpm's. Thank you
  • Michael J.
    • January 27, 2009
    • 7167
    Re: Gear ratio ??????????
    I would venture a guess of 3.55, sounds about like my '67 with a 3.55.
    • William C.
      • May 31, 1975
      • 6037
      '65 Corvette sales manual has a wonderful little chart in it regarding Speed@ rpm for various rear axle ratios, yours would be 3.36
      Bill Clupper #618
      • Michael J.
        • January 27, 2009
        • 7167
        Here's a calculator I use:
        • Jim D.
          • 2885
          If you have rear tires that are the same diameter as the originals, you have 3.55 rear end gears.
          • Mike F.
            • April 25, 2011
            • 668
            You can always jack up the car, put a mark or piece of tape on the rear wheel, a corresponding mark on the drive shaft, spin the wheel (by hand) one revolution and count how many revolutions the drive shaft makes.
            3 1/3 turns = 3.36
            3 1/2 turns = 3.55
            3 3/4 turns = 3.70
            • Joe R.
              • May 31, 2006
              • 1822
              Morris,
              Here's some more info for you:
              https://www.forums.ncrs.org/showthre...eferrerid=2667
              Joe
              • William C.
                • May 31, 1975
                • 6037
                Might also check the code on the rear axle, 3.36 -AM, 3.55-AN, 3.70-AO, if Posi, AK for 3.36 open rear 327 only. 3.36 was the most common in smallblocks by far in '66.
                Bill Clupper #618
