Spare tire fit to carrier question - NCRS Discussion Boards
  • Douglas C.
    • August 31, 1990
    • 384
    Would a 225x70x15 radial on a stock 15x8 wheel fit into my 69 spare tire carrier?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Spare tire fit to carrier question
    Doug, Yes it will. That is what I have in the tire carrier on my 73.
    • Douglas C.
      • August 31, 1990
      • 384
      Thanks Russ. My spare is missing, am I correct that the correct back spacing is 4 1/8"? Best place to buy a spare rally wheel, or maybe I'll check e-bay for a dated wheel. My 69 car was built Nov. 68.
      Tks. Doug
      • Russ S.
        • April 30, 1982
        • 2163
        Tks. Doug
        I don't know what the back spacing is with out measuring one but all you need to do is be sure you get a wheel stamped AZ and it will be correct.
          • 43279
          Russ and Douglas------
          ...and the spare tire carrier tub is the same for 1968-82 Corvettes.
          • Charles P.
            • February 14, 2012
            • 24
            Doug,
            Check the latest edition of The NCRS Driveline. There is a gentleman that has several different correct rims. I just bought a AG code rim for my '68 and at the time he had some AZ rims which is what you need. Super nice guy.
            Good luck!!!
            Charles
            • Douglas C.
              • August 31, 1990
              • 384
              Originally posted by Charles Prejean (54549)
              Doug,
              Good luck!!!
              Charles
              Thanks Charles, I'll give him a try.
              Doug
              • Erik S.
                • January 1, 2005
                • 407
                Joe / I know that all carriers are the same for those years, but in my 68 in the past someone tried to squeeze in a 69 AZ wheel with 225x70x15 spare and it cracked the top not the tub. Does that mean that somehow 68 is different or just a stupid previous owner...
                  • 43279
                  Erik------
                  If by the "top" you mean the COVER, that piece was the same from 1968 through 1974. However, it did change after 1974 and it's possible that there was some change made as a result of the change to the 225-70-15 tire size first used for the 1978 model year. Nevertheless, folks have reported that they have used a 225-70-15 spare without problems with the spare tire carrier set-up on early C3's. If it works for them, it should work for you. I hope it works for me since I plan on using a 225-70-14 spare for my 1969.
                  The other thing is that the cover is made of a polypropylene-type plastic and it is fairly flexible. I'm surprised that it would crack even if there were some interference with the tire.
                  • Douglas C.
                    • August 31, 1990
                    • 384
                    Erik------
                    Hey Joe, 225 x 70 x 14??? in your 69?
                      • 43279
                      Douglas-----
                      Nope---a typo.
                      • Jim M.
                        • February 23, 2009
                        • 233
                        225's fit fine, just adjust the back spacing down a little until it fits properly.
