I'm trying to locate a set of correct trim rings for my '68. The Judging Guide says that with the '68 rim being 7" and the '69 rims being 8", the ring will be closer to the rim on the '68. It says that the wrong depth wheel or wrong depth trim ring can be noted by the distance between the trim ring and the web of the wheel. Sooo, isn't that saying that the trim rings for '68 and '69 are different? If so, does anyone know what the correct distance between rim and ring should be. i have the correct AG code rims on my '68. With the prices for a set of NOS or re-conditioned rings, I want to make sure I get the right set. Any help would be greatly appreciated.
Thanks!
Charles
Thanks!
Charles
