C2 Broken Engine Mount Bolt (Thanks) - NCRS Discussion Boards
  • Frank C.
    • August 31, 2003
    • 171
    I wanted to thank all who advisedme on how to fix a broken off engine mount bolt in a previous thread. I did end up pulling the engine as was advised. I purchased a Kit from snap on. I have attached pictures. The bolt also as advised was very hard to remove. There would have been no way to do this task with the engine still in the car. I am going to go a head and rebuid the engine now that it is out.
    Frank
    Frank Clark
    U.S. Army Retired, current serving DoD Civilian
    C1 1962 300hp, 4spd. Black/Fawn
    C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
    C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
    C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
  • Frank C.
    • August 31, 2003
    • 171
    Re: C2 Broken Engine Mount Bolt (Thanks)
    Frank Clark
    • Tom K.
      • February 26, 2008
      • 167
      It is amazing how much work one broken bolt can lead you into. Glad to you posted the pictures. I have a similar tool from Sears, but have not yet had the need to use it. Good to see that they work. I have broken too many EZ outs through the years. Good luck with the rebuild.
      Tom
      • Timothy B.
        • April 30, 1983
        • 5192
        Great job Frank, don't let the machine shop talk you into removing metal from block and heads. Just do a stock rebuild, reuse oil pump if it's the original and in good condition, and keep those bearing clearances in the .002 range. If the bore is 4.005 or less I would consider knurling piston skirts and keep standard bore.
