C2 _Ignition switch does not kill engine - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    In my friend's 63, the engine starts normally but does not shut off when the ignition switch is turned to the off position. At the suggestion of others he has replaced the ballast resistor and the voltage regulator with no results. The alternator has also been suggested as the culprit. Any ideas?
  • Steve D.
    • February 1, 2002
    • 990
    Re: C2 _Ignition switch does not kill engine
    Please ignore the post. I posted the same question last year and finally found it in the archives. (He is slower than I am and still hasn't fixed the problem)
    • Ray G.
      • May 31, 1986
      • 1189
      Hello Steve;
      I'm not clear. Have you found the problem?
      1963 being the first year for alternators on Chevrolet, as I recall there were some ghost wiring problems.
      i.e.; with the left directional on and your foot on the brake the car would run on feedback through the flasher unit, with the ignition key turned to off.
      Also possibly a bad alternator diode feeding back through the ignition switch.
      Maybe someone with historical documents will remember these situations and chime in here.
      Ray
      I hope you dance
      • Steve D.
        • February 1, 2002
        • 990
        Ray
        Thanks for your comments. Since the switch functioned well for a long time prior to the present condition, I am suspecting that a short has occurred. We are going to check the solenoid, then the harness if necessary.
        Steve
