Stamp block # 4743 - NCRS Discussion Boards
Stamp block # 4743
  • Morris R.
    • May 7, 2012
    • 213
    Stamp block # 4743
    Does anyone know what block stamp #4743 mean? Coming off a 66 corvette holley carb 3884505 listing 3367. Thank you
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Stamp block # 4743
    Where on the block is this stamped?
    • Page C.
      • February 1, 1979
      • 802
      The 4743 is the correct number on the primary metering block of a 3367 Holley used on a 1966 Corvette 327/300hp.
      Page Campbell
      • Frank C.
        • August 31, 2003
        • 171
        I have posted a picture of the 3367 from my car. The metering block 4743 is what should be on your car if it is a 327 300 hp or 350 hp minus A.I.R. The 327 with A.I.R. option uses a 4920 metering block per the fourth edition judging guide page 68.
        Frank Clark
        U.S. Army Retired, current serving DoD Civilian
        C1 1962 300hp, 4spd. Black/Fawn
        C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
        C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
        C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
        • Timothy B.
          • April 30, 1983
          • 5198
          To add to the posts above, this 4743 metering block houses the main metering jets as well as the idle feed restriction and power valve. These factory calibrations are used for the 300 & 350 hp engines.
