M21 Muncie speedo gear - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    Due to the total lack of normal intelligence, I managed to drop the speedo gear in the tail piece of the transmission. Any suggestions of retrieving this gear without removing trans from car. Oh yes , a m21 in a 57. any advise would be apprecianted.
  • James O.
    • November 1, 1985
    • 160
    Re: M21 Muncie speedo gear
    Done that. I don't think you will ever get it out. Hey, its plastic. Let it live in there and buy another. Jim O.
    • Jerry B.
      • August 31, 1994
      • 416
      Thanks James. Do you think it will damage any bearings or gears
        • 43248
        Jerry------
        The speedometer gear is in the extension housing, not the main case. Consequently, the only gears it could be "churned up" and "interact" with are the reverse gears. I don't think it would really damage these if that happened.
        • Jerry B.
          • August 31, 1994
          • 416
          Thanks for your quick responses. However, I hope my mistake does not cause me any more grief.
          • Richard F.
            • May 31, 1986
            • 193
            Seems like a lot of them come out of their normal hole with almost no teeth anyway. You are just completing the job.
