69 Alternator on Ebay... - NCRS Discussion Boards
  • Grahame M.
    • November 7, 2011
    • 225
    Hi Everyone,
    I noticed this Alternator on Ebay and was wondering if the date code of 9A7 would fit with a July 69 build car? Also, is it the correct part for a 69 L68 with Air, Pwr Steer & TI?
    Cheers
    Grahame
    69 427 Tri-Power 4 Speed
    Black on Black
    • 43289
    Re: 69 Alternator on Ebay...
    Originally posted by Grahame McCann (54038)
    Hi Everyone,
    Cheers
    Grahame
    Grahame-------
    The date code of January 7, 1969 would be outside the "6 month window" if your car was built after July 7, 1969.
    The alternator is configurationally correct except for the installed fan and pulley which are not correct. Whether this is an original stamping is another matter. In my opinion, it is not.
      • 11698
      Agreed.
      Just saw one like this at the Chapter meet 3 weeks ago. It's a restamped unit.
      • Grahame M.
        • November 7, 2011
        • 225
        Thanks for responding so quickly. Can you suggest someone?
        John Pirkle?
        Cheers
        Grahame
        Black on Black
        • Ken A.
          • July 31, 1986
          • 929
          Grahame-------
          Why do you say it it a restamp? Is it because the letters & numbers are so uniform? I looked at 6 of them on our shelf (all 63 amp) & none were as nice as the picture. Most were a little faint & 1 was completely blank.
          • Terry B.
            • August 31, 1999
            • 607
            John Pirkle has my vote for Corvette alternators, starters, voltage regulators, horn relays and anything else that he carries. You know it done right and is correct with Pirkle.
            Terry Buchanan
            Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
            Corvettes Owned:
            1977 Coupe
            1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
            2003 Electron Blue Coupe
            2019 Torch Red Grand Sport Coupe
              • 11698
              Here is the alternator in question:
              Irregularities I see:
              1100825 - not on the same horizontal plane, spacing is irregular, different fonts used, varying depth from character to character
              9A7 12V Neg- again not on same horioontal plane, poor spacing, should be "12VNEG" not "12V NEG"
              I'm sorry, but that restamp was done one character at a time and shows it.
              Originals were roll stamped all at the same time.
              Here is a real one:
              Patrick
                • 43289
                Ken------
                Yes, the uniformity of the characters is part of it. Otherwise, it just doesn't "feel right" to me. Hard to say exactly what influences that perception.
                • Jeffrey S.
                  • May 31, 1988
                  • 1902
                  I just checked the 825 alternator on my '69 that I know to be original and here is my observation. The part has no space between the "1100" and the "825" It is stamped "1100825" not as shown on this piece. The "G" in NEG is even with the other letters. On this one the "G" appears to be lower than the "NE". Mine is much earlier (Oct '68 car) and I'm sure that it is possible that different batches had different stamping patterns. Just thought I woud point this out.
                  Jeff
                  • Patrick N.
                    • March 10, 2008
                    • 954
                    Out of curiosity, what are the thoughts on this other 1100825 being offered? they seem to have the same elements in question?
                      • 11698
                      http://www.ebay.com/itm/69-Corvette-...#ht_500wt_1413
                      I think it has been massaged better than the first one.
                      • Dick W.
                        • 10483
                        All I will say is that David is trying to get his restamps by, lacks quite a bit yet.
                        Dick Whittington
                        • Patrick N.
                          • March 10, 2008
                          • 954
                          At least the two in question are consistent with each other if nothing else
                          • Grahame M.
                            • November 7, 2011
                            • 225
                            It's great to have a check and balance like this forum. I'm trying to get some information by ema from John Pirkles, without luck. Living in Australia makes it harder but should I ring instead?
                            Thanks again : ))
                            Black on Black
                            • Gary H.
                              • June 8, 2008
                              • 308
                              My July 69 L36 with C60 Factory AC has the original 1100882 61A alternator. You can still see the original ink stamp. It is dated 8K30.
                              Gary
