Hi. On my 69 L68 I find a MS 360 12 advance pod. Am I correct this is for 12 degrees advance @ under 12" of vacuum?
And, as my L68 is stock except for a Comp Cam 280 Magnum cam is this a good choice? Meaning lets say 34 degrees all in mech. at around 2,800 rpm's, then 12 degrees more under cruising situation? Plus, I will use vac. adv. manifold vacuum to get a smooth idle.
Also, should the vac. adv. arm have a small rubber bushing or is it just the plain metal bent rod?
