What is a B1 vacuum advance? - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5202
    #31
    Re: What is a B1 vacuum advance?
    So if a solid lifter big block with high overlap camshaft used ported advance and approx. 12* inital timing in 1966 what was GM looking to solve.
    I don't think that's any where near enough timing at idle but the benefits of vacuum advance by that time were well known.
      • 15706
      #32
      AIR with ported vacuum advance was required for California L-72s and L-71s in '67 to meet tailpipe emission standards. GM decided to use the same carb for 49-state verisons even though ported vacuum advance is not ideal for non-emission controlled engines.
      Because these were low volume engines, it might have just been a cost issue - use the same carb rather than re-engineering it for full time vacuum advance and having another part number to inventory.
      • John D.
        • December 1, 1979
        • 5507
        #33
        Originally posted by John DeGregory (2855)
        According to a Delco Remy specification manual a 163 and a 201 vacuum advance are close but not the same.
        '163 specs in laymans terms. : Starts at 8 to 10. All in at 16.25 to 18. Moves 8* which is 16* crank.
        '201 specs ---------------------: Starts at 7 to 9. All in at 15-16. Moves 8* which is 16 crank
        '236-16 specs------------------: Starts at 3 to 5. All in at 5.75-8.25. Moves 8.2*
        Error factor in all of the above is 1 degree plus or minus.
        Credit for the above information goes to Don Baker.
        If I were you I would print it and save it.
        JD
        FOR: Dennis Kurmai
